well then shame on you for thinking it was hard!!!!!!!!chilli said:if I can redo a top end, add reverse to an SRX, I can surely adjust PVs...LOL
.....chilli said:OK, so when I am wanting to disassemble the power valve, and release it from the cable, how do I go about that?turn the servo clock wise till there's lots of slack in the cable,,then remove your 4 screw's that hold the housing to the cyl,pull out the valve slide the cable out.
What about the servo? Ive takn it off but thats it for now, do you make the marks now before touching anything, or only when adjusting?why did you remove the servo,not needed remount it back on..
Thanks Spaz.Spaz's SRX said:FYI - I did a test last year running Yamalube in my "01" SRX and Amsoil in my "98" SRX. The "01" broke down mid way through season because of shock issues. By the end of the season the "98" had nearly twice as many miles on it using only Amsoil and the PV's were 10X cleaner than the "01's".
Thought this might help for future cleanings.
rx1jim said:The coating on the power valves is aluminum oxide. This coating is applied to the power valves using an electrolytic anodization process. The aluminum oxide is approx. 0.001" in. thick. The purpose of the aluminum oxide is to provide a very hard and durable surface so the carbon deposits can be removed without damaging the aluminum base metal. DO NOT use oven cleaner, strong detergents such as Castrol super clean or any other cleaner with a high pH (cleaners containing hydroxides) Oven cleaners and the strong detergents dissolve aluminum very quickly. Members of this site insist on proving this fact several times per season. The aluminum oxide layer is insoluble in these cleaners however the coating is not pinhole free. Soaking the valves in these strong hydroxide cleaners allows the cleaner to penetrate the pinholes and imperfections in the aluminum oxide and dissolve aluminum base metal therefore destroy the valves. The power valves are completely safe when cleaned with solvents: carb cleaner, brake cleaner, penetrating oil, etc.. I use a scotchbrite pad with fast orange hand cleaner. The pumice in the fast orange hand cleaner with the scotchbrite pad removes the carbon residue and does not damage teh aluminum oxide coating. I clean and adjust the power valves on mt 2 SRX's every 700 miles. Cleaning the more often allows easier cleaning. It takes me less than 5 min. of scrubbing per valve to get them completely clean.
DO NOT USE OVEN CLEANER OR STRONG DETERGENTS UNLESS YOU WANT TO SPEND MONEY ON NEW VALVES!!!
