carbon on the power valves
hickey's got a yami
maine
the center valve has more carbon then the 1-3 valve. its on the outside edge more than the middle. is this normal?? not bad tho. AMSOIL did the trick
I usually have one that has more buildup than others, Most likely it runs alittle richer, More oil/gas. builds up a little more. Its normal.
If you have power valves with the coating scratched off, the carbon likes to stick to those areas.
