Hey fellow S10 owners,
I was wondering what you guys are running for tires/wheels. I'm in need of some new tires. I have a 2000 4x4 extended cab, with Motomaster Roughrider 235/75R15's. That's what was on there, and they are in pretty good shape. One I had a bad Passenger side ball joint (Bought it like this) And the front pass. tire is pretty worn on the outside.
So I was thinking about getting some 275/60R15 for the rear. 255/60R15 for the fronts. I'll be dropping the truck a bit 1"/2"...... Just looking for some options.............. And pics.
Nik!
Nik!
T.S.U.Filmz
i have an s 10 but it is lifted with 31's not dropped
Do you have any rubbing issues? What about before you lifted it? I was also considering 31x10.5R15's.
blueblooded
^^^Nice,ive always liked the s10.My first brand new car was a extended cab s10.I traded that in for the crew cab s10,both great trucks.Gm screwed up when they stopped producing them.
xt700
- Jan 27, 2006
think you might have to run the same size rubber all around or t-case problems could come up.
Pat
Pat
xt700 said:think you might have to run the same size rubber all around or t-case problems could come up.
Pat
Yeah I was thinking about that. Never had a 4x4 truck before, lol.
my buddy runs nothing but bfgoodrich all terrains. He loves them, they give good grip and a pretty good ride for as aggressive as they are. I had a pair on a bravada few years back and couldn't get that thing stuck if i wanted to. As far as size you can run 31x10.5 without a lift but you have to give the torsion bars a bit of a tweak so the front don't rub, unless its a ZR2 then there stock.
T.S.U.Filmz
no rubbing issues now before the lift i had a little rub when turning and hit a bump at the same time. i don't know the exact size of tire but they are 31's on a base S10 with a 3in body lift and 3in suspension lift
Like i said though to get around a lift temporarily is just tighten down the torsion bars on the front just a bit and the bumps and turns will be fine. I bet if you check some boneyards you can find a S10 ZR2 pick-up or blazer. Pull the suspension on it and put it on yours and voila 3" suspension lift, for less than an aftermarket.
joe.snow said:Like i said though to get around a lift temporarily is just tighten down the torsion bars on the front just a bit and the bumps and turns will be fine. I bet if you check some boneyards you can find a S10 ZR2 pick-up or blazer. Pull the suspension on it and put it on yours and voila 3" suspension lift, for less than an aftermarket.
I cranked the T-bars months ago and got a good 1.5" out of it. I want to drop it a bit, I prefer the lower trucks.
Buy a 2 wheel dive and put a drop kit in it.
joe.snow said:Buy a 2 wheel dive and put a drop kit in it.
Um... Yeah... NO!
Don't even start with "Why lower a 4x4?" BullSh*t. It's my truck and I'll do as I please! You understand that now.
Dude you need to calm down. YOU WERE ASKING ABOUT 31'S all i did was answer. Then you say i like the look of a lower truck can't have it all. If you wanna get an attitude you can piss off. YOU UNDERSTAND THAT!!!!!!!!!!!!!!!
joe.snow said:Dude you need to calm down. YOU WERE ASKING ABOUT 31'S all i did was answer. Then you say i like the look of a lower truck can't have it all. If you wanna get an attitude you can piss off. YOU UNDERSTAND THAT!!!!!!!!!!!!!!!
I was asking for tire opinions. I was thinking about 31's, But I want a lowered truck. So obviously 31's aren't possible. I've been putting up with the "Buy a 2wd" On all the S10forums, and don't want that BS here. So sorry if I sounded like an ***, But that's the way typing makes it seem. I'm very calm, and have no "attitude".
I understand its your truck and you can do what you want. 31's will rub like a sonofagun without the t-bar tightening. If i remember right stock S10 sizes is 265-70-15's correct. You can run the different sizes front and back, we don't have any probs on the mudtrucks, you DO want to run same gearing in the front and rear diff's b/c of the t-case.
joe.snow said:I understand its your truck and you can do what you want. 31's will rub like a sonofagun without the t-bar tightening. If i remember right stock S10 sizes is 265-70-15's correct. You can run the different sizes front and back, we don't have any probs on the mudtrucks, you DO want to run same gearing in the front and rear diff's b/c of the t-case.
There are some options as far as tire sizes. On my truck 235/75/15 is the stock size. I'll see what happens, But since winter is here I'd rather not start messing with things, Especially since I'm working all day everyday again.
dirtjumper895
well i got a zr2, i have it on 32x11.5x15's .... heres the pics.
and 275x45on 20's
and on 31x10.5x15's on American Racing Wheels
Ill whore this one in there too.
and 3 days before the accident. the last picture i took of my baby.
and 275x45on 20's
Now that's a sweet truck!!!!
RIVERRUNNER
I had a s10 for years ran bfgoodrich at best tire on the market for the price......if you run around off road at all. I get about 50,000 miles out of a pair!!! You can fit 30x9.5 on your truck without doing anything, and they are about 1/2 inch bigger then 235's.My .02 cents!!!!
dirtjumper895
Thanks... Its for sale too.... I want a full size.
