Hi everyone. I have a 2001 SRX700 and the crank is starting to come out of phase (she has 10,000 kms on her). I am looking at re phasing and welding and replacing the bearings but I have come to find the bearings have gone way up!!! apprx $1600. Does anyone have a source for these that are a little more reasonable? Or any other suggestions?
bluwulff9
did you try looking at Canadian Bearing. I know that they make all kinds of bearings. Just a thought.
i thought 98 was the ones that went out of phase ? or did 01 have the same problem?
no.....
'01 srx's was welded from the factory.
Yamidude59
Still probably a good time to do a ring job and replace crank bearings and true the crank shaft . no need to weld.
9801srx
why do you think your crank is going out of phase? on a welded crank it is pretty much impossible for it to go out of phase unless the welds have broken.i don't think you can get the bearings anyware but yamaha.
progold
Just a thought but did you consider looking for a used engine with low miles on it maybee from a scapped sled it would probably be a lot cheaper than a total rebuild ,just a thought.
surely someone knows of a bearing source besides oem?maybe ntn?or federal mogul?
like progold said it would be way more cost effective/time saver just to find a good used compleat crank...then just R/R it...
mopar1rules
try contacting jeff @ midwest crank in green bay wisconsin. he has bearings in stock and can rebuild your crank for you.
920-434-3630 jeff @ midwest crank
Are we all sure that 2001 had a factory welded crank and cannot come out of phase?
SRX44 said:Hi everyone. I have a 2001 SRX700 and the crank is starting to come out of phase (she has 10,000 kms on her). I am looking at re phasing and welding and replacing the bearings but I have come to find the bearings have gone way up!!! apprx $1600. Does anyone have a source for these that are a little more reasonable? Or any other suggestions?
Try these guys...online quote are close...they have exchanges as well...good luck & keep us informed...
http://www.cvtech-aab.com/contenu/index_ang.cfm
SRX44 said:Are we all sure that 2001 had a factory welded crank and cannot come out of phase?
yes they were welded, updated 1999+ and no problems that i've ever heard
of ever came up..
