bluehammer
Pull the pipe off the dead cylinder and see if it is plugged. The pipe may be full of fuel or perhaps a mouse nest. See if the cylinder will fire without the pipe on. Pull the reeds and see if one is broken. Use a new spark plug when you get ready to pull it over.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
he already found out the problem! and usually they are for stupid reasons like this one that make you want to go
awesome...glad she is all fixed
bluehammer
So what did ya find wrong?
jvizzacc
Problem solved
A brand-new NGK plug was no good.
When I tested it I did the standard "rest it on the head" trick, which produced a blue spark. But I didn't look closely enough at the PLUG. I suppose what I saw was the blue spark between the plug and the head, NOT between the plug electrodes. But since it was a NEW plug, I did not assume that it could be bad.
Ya know what they say about ASS-U-ME, right?
Anyways after the folks on the forum agreed that it is possible for a new plug to not function correctly I went home and simply moved #2 (new) plug to #3, and #3's to #2. Lo and behold the problem followed the plug and #3 was not firing. Put ALL NEW plugs in and it runs great.
But sonnovabeetch that was frustrating. Those BR9ECS plugs are like $7 each too! But in the long run, the problem was a bad plug. Cleaning the carbs has made the sled a lot easier to start, but really wasn't the problem.
Thanks for everyone's help and opinions on this!
Jim
Jim
