Lester
I have a 01 srx with a m-10 rear suspension,I want to install a 1 1-2 or 1 3/4 track,will either one fit?
with 8 tooth drivers
Lester
will it fit with stock drivers
cacsrx1
Yes, you may have to remove the protector for the front heat exchanger.
I ran a 1.5" lug Ripsaw last year in my '02 SRX. To get the proper clearance, you will need to remove both the tunnel and front heat exchanger protectors. No problem with sticking with the stock 9 tooth drivers.
To run a 1.75" lug track you will need to use 8 tooth drivers.
what about a 1 1/4 track..will i have to pull out the tunnel protectors?
SiR X700
track
Yes. With stock drivers. Or you can cut the lugs down
yam_apex91469
you can go to 2" with 8t drivers and the protectors removed. 1 1/2" will work ok with stock drivers and protectors removed
You can notch the track where the protectors are and run it that way, I have one like that now. Original drivers, protectors in, lugs notched. 1.5 track
edgeracer1
I ran one on a 2000 srx just by notching the track for the protectors.
so would i have to notch a 1 1/4 track? or only if you run the 1.5?DV8 said:You can notch the track where the protectors are and run it that way, I have one like that now. Original drivers, protectors in, lugs notched. 1.5 track
