1 1/2 track on srx
Lester
Bootlake Mi
I have a 01 srx with a m-10 rear suspension,I want to install a 1 1-2 or 1 3/4 track,will either one fit?
I ran a 1.5" lug Ripsaw last year in my '02 SRX. To get the proper clearance, you will need to remove both the tunnel and front heat exchanger protectors. No problem with sticking with the stock 9 tooth drivers.
To run a 1.75" lug track you will need to use 8 tooth drivers.
You can notch the track where the protectors are and run it that way, I have one like that now. Original drivers, protectors in, lugs notched. 1.5 track
so would i have to notch a 1 1/4 track? or only if you run the 1.5?
