Studding an MSRX
phazerguy
SE WI
Has anyone studded an MSRX with the stock 1.5 inch track? I was thinking about doing it, wondering how long of studs I could run if at all?
Do they even make studs longer then 1.5? they would have to in order to even benefit from it. Your best bet would be to cut the lugs down to 1 inch and go with ATLEAST a 1.125 stud after you add tunnel and heat exchanger protectors. If you dont add the protectors, I am afraid you will have a very short riding season.
