Rpm question on my srx..
patsxr700
Tupper Lake
Srx is supposed to run at 8,500 rpm right?? It runs at 9,000 i think its over reving.. what should i do set the spring tighter?
Don't tune with the secondary. Add weight to the tip of the Weights.
EDIT: Also, What helix are you using? Is the belt new? If not an old worn belt could over rev.
what is your secondary spring currently wrapped at and what spring are you using? what is your helix, primary setup, and gearing? was the sled working fine at 8500 and then now all of a sudden its running 9000?
I just bought it.. its a stock 2001 srx with a bender can on it.. thats y i am asking this question because i was wondering y it was running at 9 grand.. on a stock srx..
Change the belt, a worn belt will over rev. What weights are in the primary stock 8DN-20's?? With 4.5G in each hole? Just try adding weight to the tip of the weight. Change the belt and and see if it lowers the rpm on topend.
