craigjschr
I picked up my 2002 sx viper 700 ER and i took it for a spin and put it into reverse and the sled pulled way down and i hit my heat exchanger i did not go through it but i do not want to so any help would be great. i have a 144 golddiggers on it.
thanks
thanks
blueblooded
Did you back over your mudflap? You should have rear heat exchanger protectors if your running studs.
craigjschr
yea thats what happend whare can i get the protectors from.
blueblooded
Any yamaha dealer should be able to get them for you.Try Rich motorsports also,Im sure he can get them.
craigjschr
do i need any for the front.
craigjschr
are they easy to install.
blueblooded
Yes,you should have them up front also.They are easy to install,just pop rivet them in.
craigjschr
do i have to pull out the track.
blueblooded
No need to remove the track,you will have enough room to get them in.The protectors up front have a pin on one end and a plate you rivet to the belly pan on the other.You drill a hole in the top of the tunnel,then put the pin end of the protector in the hole you just drilled.Then you just pop rivet them in from the bottom.Its easy.The rear are even easier.
blueblooded
You will need to buy a long drill bit to drill the holes up front because there isnt enough room to get the drill motor in there if you use a short drill bit.
craigjschr
can you get me a pic of thier placement on the sled if you got one.
thanks
thanks
blueblooded
I have a set on my sxr,i'll post a pic tomorrow.
craigjschr
thanks i can find these protector rich motorsports is out of stock and i went through all of ty vendor list.
blueblooded
Try Don Georges sports center in clarence ny,thats where i bought mine.I believe the # is 716-759-6837.
