bfrap5
help I have a 2000 sxr600 I throtle hard to 7-8000 and let up and motor wont let me throtle until rmps come down to almost and idle its not poping or chocking or stalling out. help me!!
blueblooded
It revs great to 8000,then you let off and hit the gas again and it bogs?? Sounds like its not backshifting correctly.
bfrap5
00 sxr600
problem: throtling sled to about 7-8000 rpms and let up, and it wont let me continue to throttle unless i bring the the rpms down to almost an idle. press and press the throtle and nothing happens.. help me!!
Or the TORS is kicking in..... Link in my sig.
blueblooded
Would the tors let it rev that high if it was malfunctioning? When my tors acted up i could hardly rev it up to get the clutches engaged.
Merged and moved this thread.
The TORS may be a result of a sticky throttle cable (the design intent). Sled works fine to xxxx RPM but goes to TORS because the carb or flipper switch fails to be made on release of the flipper..... Not saying that's it, but it's pretty easy to rule out.
bfrap5
whats a tors?
horkn
doesn't sound like tors,,not backshifting if ya ask me...we need yourbfrap5 said:help I have a 2000 sxr600 I throtle hard to 7-8000 and let up and motor wont let me throtle until rmps come down to almost and idle its not poping or chocking or stalling out. help me!!
clutch set up(secondary)
does it bog when you press and press the throttle or does the motor do nothing? It seems to me the motor will have a tendancie to bog if it were in the clutching and do nothing if it were related to the tors.
bfrap5
no boging or poping no hesitation allmost like its loading up from back to back throtling and when the r,s get up there you try to throtle again and it doent respond.
horkn
Sure sounds like the clutches are not back shifting to me as well.
bfrap5
no boging
bfrap5
how do fix o r adjust the back shifting on the clutch
we need you clutch set up.......wrap, spring, helix..
First of all, check the TORS system. It's super easy to do and should be eliminated. Check post #9 in this link. http://www.totallyamaha.net/forums/showthread.php?t=53216 (Make sure you have the track off the ground when you try this)
If nothing happens during the test, then the system is likely bypassed and it's not the source of your problem. If it acts the same way during your test as it does when you're driving it, then post for some help. If it doesn't act the same way, then get after the clutches.
What's the mileage on the sled???
