The PALE OIL, NAPHTHA, and "ISO" alcohol you can buy for about 2.00 to 3.00 a gallon, get a 5 gallon STEEL ungalvanized BUCKET and use their msds and LOOK AT THE PERCENTAGES and make FIVE GALLONS for about TEN DOLLARS.... you'd have enough SEAFOAM to last you A SEASON OR TWO for ALL YOUR VEHICLES for the price of TWO CANS of seafoam.... THE TRICK IS,,,, KEEP the container TIGHTLY SEALED and in a CONTROLLED TEMPERATURE ROOM!!!! The ALCOHOL, when left open,,, will ATTRACT MOISTURE and RUIN your seafoam!!!! The PALE OIL AND NAPHTHA will also evaporate if not kept tightly sealed... Let us know when you make a 5 so we can MOOCH some from you....Gary oles nosboy
Apsley Max
Check out youtube, punch in Sea Foam.Engines are my life,if I were you I would stay away.This crap causes more problems for people than help. Its no substitute for proper engine servicing.Mind you some people on there aren't using it correctly.Dumping it intake[or in brake booster hose] is surely detrimental to your engines health.
sleddheadd
Any one ever tried Amsoil P.I performance Improver? Several customers have tried it and agree it is better than Sea Foam! And it contains no Alchohol. If you get the oprotunity give it a look and maybe a try? You will be happy with the results! https://www.amsoil.com/a/Fuel-Additives-Performance-Improver
Here is a copy of the MSDS https://www.amsoil.com/msds/api.pdf
Canuck
What is "Pale Oil"?
sockeyerun
Test Dummy
I had tried searching for FITCH and nothing came up. I was thinking I had read about them in an earlier thread.
The whole reason I asked these questions in the first place is, I'm installing a set of SLP pipes on my 02'MM right now and I just want to protect my motor. I have always been careful when it came to my fuel system as I have stated in a earlier post. I am just wondering if their is a product that would maybe give some added protection to what I am already doing? Bad gas is already my enemy....
pale oil is basically a light colored lubricant that really has a mild smell, that the "trades" use for processing/ lubricating suede and leather to preserve it.. it has a bunch of other uses, but the majority is used for lubrication...
go to the general area,, it's right above this post!
FuzzButt
http://www.totallyamaha.net/forums/showthread.php?t=41881
Is the Fitch link I think you wanted.
If the local search does not work for any item on this site then try google.
In the search box on google.com type this:
site:totallyamaha.net what-ever-you-are-looking-for
So for the Fitch I typed in
site:totallyamaha.net FITCH fuel catalyst
sockeyerun
Test Dummy
Thanks for the info. There are some subjects and threads I know I have read, but could'nt find them later. Even my own. Soc
yamachuck
logical explanation.good job
