Pulstar™ pulse Spark plugs-more HP & MPG
SledBoy
Stillwater,MN
Anybody try these in a sled? What's your opinion on these?
www.pulstar.com
Pulsed Power Technology in a performance auto part increases horsepower while at the same time increasing gas mileage! That's right - you no longer have to give up gas mileage to increase the power and productivity.
DirectHits®, the original concept behind the new Pulstar™ Pulse Plug, delivers the same punch and power of Pulse Plugs. Although, in some instances, Pulse Plugs may not currently be available for every engine manufactured, you can still benefit from this revolutionary technology. In cases where an aftermarket turbocharger, supercharger, nitrous or any other product that increases displacement or compression has been added to an engine requiring a colder plug to avoid possible engine damage, DirectHits® is the perfect application. DirectHits® must be used with NON-RESISTOR PLUGS ONLY.
Similar to Pulstar™ Pulse Plugs, DirectHits® accumulates ignition power and releases the stored power to the spark gap. Virtually every spark plug on the market today (SplitFire®, Platinum, Iridium) is a Low Power Discharge plug (LPD) having a peak discharge current of between 0.020 to 0.060 amps. DirectHits is a High Power Discharge spark plug (HPD) generating 500 amps of peak discharge current... 20,000 times more power than LPDs. Power to really ignite fuel! The robust DirectHits® spark burns the hydrocarbons in the fuel more completely and consistently so fewer hydrocarbons escape to the exhaust. DirectHits® does a great job at igniting hydrocarbons at lean air:fuel ratios conventional spark plugs could not begin to ignite.http://www.pulstar.com http://www.pulstar.com
I dont believe any claims that something as simple as sparkplugs will increase horsepower and improve milage.
They made these claims with Splitfires and Bosch +4s and there is no data to support those claims.
