Ix Josh9056 xI
my secondary clutch is not back shifting and up shifting too fast. also i was ridding today and the belt got stuck in the clutch and i had to pull the belt out to get the clutch to close
Check bushings & your plastic pucks that the helix rides on.
Ix Josh9056 xI
thanks i have another clutch i think ill just put that on. what should i wrap it at its a stock black spring?
Ix Josh9056 xI
any 1 no what wrap i should have my spring at???
Ix Josh9056 xI
thanks
Ix Josh9056 xI
the belt is now slipping when it go up hills.
i have it on a 60 wrap
tedgoesfast
explain in more detail
Ix Josh9056 xI
i could here the belt slipping when i get on it hard or go up hills
You really can,t hear a belt slip. You can feel it & watch it on the tach.
Hey..I have a brilliant thought.
is your track slipping on the drivers. I think this is what is happening & you are thinking it,s the belt slipping. Check track tension...I bet thats your cupret cus coutches just don,t do that!
