yup, thats one of the reasons i run
swmichsx
the blinker fluid and muffler bearings are in the same isle as the piston return springs.
Yep next to the Sky hooks, long wait and the tartan paint.
You rock there daman.LOLdaman said:yup, thats one of the reasons i run![]()
By the way..I have tried the muffler bearings,and the damn things work GREAT!!!! They are a great invention to. lol and lmaorof
ya know they make a synthetic now???swmichsx said:the blinker fluid are in the same isle as the piston return springs.
TJ500
I use Yamalube for my non powervalved sleds because it's recomended by Yamaha, and, it's cheap relative to Amsoil... If Amsoil prices were similarily priced, I'd give it a try... (any Amsoil dealers near Winnipeg willing to sell for similar price?)..
10-12 bucks/946 ml for a consumable oil that just pukes from the exhaust and sticks to the trees is too much money for me...
Does Amsoil have a special refinery that specifically makes their own two stroke oil?..
just wondering?... thanks TJ..
TJ500..ain't it the truth. But I run whatever daman runs....lol
I see Walmart now carries Piston bearings that replace the rings.They would last a long time to I Imagine...lol
the thing is TJ with some tuning to your oil pump you can get it down to say 40-50:1 then the consumption would be way less,,making it worth the $$.
plus you'll go longer between ring jobs with a full syn.
.................do some research on the shear factors of high end oils such as amsoil, and 'ordinary oils'.
TJ500
daman said:the thing is TJ with some tuning to your oil pump you can get it down to say 40-50:1 then the consumption would be way less,,making it worth the $$.
Hi Daman... It still calculates to a very expensive consumable oil... I am still hoping to hear from a local Amsoil dealer that will make it worthwhile for me...
I would like to use a full syn that is affordable... thanks tj
Understood..you do whats right for you.TJ500 said:Hi Daman... It still calculates to a very expensive consumable oil... I am still hoping to hear from a local Amsoil dealer that will make it worthwhile for me...
but since i tuned in my oil pumps a tank(2.5 qts) goes a looong way..
Dnrtheil
Thanks for setting me straight, all these years I truly thought the "W" stood for weight.
Blinker fluid
Derek
Blinker fluid
Derek
sleddheadd
THE AMSOIL CORPORATE HEADQUARTERS, MANUFACTURING PLANT, AND MAIN DISTRIBUTION CENTER are located in Superior, Wisconsin, with several regional warehouses strategically located throughout North America and overseas. These facilities cover a total of nearly 700,000 square feet.TJ500 said:Does Amsoil have a special refinery that specifically makes their own two stroke oil?..
The state-of-the-art lubricant production plant contains materials blending and bulk storage facilities, as well as highspeed bottling lines and packaging equipment. The main warehouse serves as the hub of a global distribution network; bottles, cases, drums and totes bearing the AMSOIL label are shipped worldwide. Capacity is geared to meet projected market demands decades away.
The AMSOIL administrative functions are centrally located and outfitted with the latest in communications and information processing equipment. The entire complex is staffed by a cooperative, knowledgeable and well-disciplined team of approximately 300 employees.
horkn
Dnrtheil said:Thanks for setting me straight, all these years I truly thought the "W" stood for weight.
Blinker fluid
Derek
Hey, no problem
I wonder when the blinker fluid will be back in stock? I am out, and the blinkers obn my sled won't work until i replace the fluid.
FuzzButt
I think both of my Chevy's could use some of that blinker fluid. Both of them go thru blinkers/DRL's. I'm getting tired of changing them.
I found www.kalecoauto.com a few years ago, and it still makes me laugh.
The O-pipe exhaust
Spark plugs that actually plug the spark
Cross-drilled brake lines
Engine oil bypass kit
Radiator insulator
710 cap
Wiper blade sharpener
These are all must have items.
I did buy one their "Check Engine Light" T-shirts a few years back.
The O-pipe exhaust
Radiator insulator
710 cap
sandmanmike1
Where is the Citgo sea and snow hiding in southeast MI I live in wyandotte MI 48192 and cannot find the Citgo anywhere.
Dave M
Check out your local Gander Mountain..in the boating section..
Your other possibility is to contact Beebe oil... they are the Citgo dist. for your area.
