viperdougc
I have been looking thru the tech section and reading thru some posts. I am putting a 2004 viper motor into my 2002 viper chasis. The tech section has some clutching set ups for the 2002 and 2003 viper trail but not 2004. Will those set ups not work in the 2004. The one I like is the simplest....green spring with a 53/43 helix.
Are they not the same and once I put in the motor should I be changing the clutching on my stock 2002 clutches.
help would be good????
xsivhp
04 and 02 no clutching changes. try the green spring and the 53/43, i have it and like it, some have tried it and don't.
viperdougc
will do thanks.....what was the end result for you...why do you like that setup???
xsivhp
picked up a few sleds lengths on the lake, seems zippier in corners, actually improved gas mileage. I think I have 70 deg of twist on it if I remember right.
