kallio
KR - do you have any photos?
Hi kallio
I don't have any pictures, looks like a normal Phazer 2 with a shift knob at the right rear of the hood.
I don't have the sled anymore otherwise I'd get a picture or 2.
Ken O
Ken O
HI Ken
Just saw your posts about the reverse add-on to a Phazer 2, just picked up a 91 phazer 2 and planning to do the same. Had question for you on the parts swap, you noted that need a venture jackshaft as well to match the venture reversing chaincase, is there anything else on the secondary clutch side that needs to change (mounts, bearings, etc.) or does the venture jackshaft mate with the phaser clutch assembly as-is? Also, for the drive axle assuming you had to change the drive sprockets... the phaser sprockets fit fine on the venture axle?
kevin
kevin
