It worked good. You will need to use scratchers when you run on the hardpack but you should be using them anyway with a 2" track to prevent hyfax wear and engine heating. I'll be honest, in the powder it is really hard to tell any difference between a ported track and a non ported track, but it looks cool. BTW, I noticed no track stretch after porting. Do not cut the holes on the outside of the drivers. Seen some tracks fail when the 2 outside holes are drilled.
