srx 700 power valve trouble !
PowerValve
sweden
:2strokes: power valve on my srx 700 (2000) does not work . o have fix the wires and valves . but servo engine is completely dead. the servo engine has work previous. I have heard that it may be the cabling may be faulty, but I'm not really sure there is electricity.
but my dad has been and pills in my scooter when not tank meter worked. he got it and work but it seemed that the exhaust ports and servo motor stopped working.
he mendae that it was reaching failure of relays in cable strain. but fathers is that they are they have always found their rings and reflections.
I seriously need help and I am grateful if you help me!
:2strokes:
First of all, what the heck did you just say and secondly take the cover off of the servo motor. Start the sled and with the hood open flip the choke lever and get the sled to start to stall out. Watch the server motor and see if the cable activate and pull back, this will tell you if the powervalves are working at the motor. This would be what I check first. IF all is good take out the powervalves and make sure the cables have not pulled through the powervalves.
remove your servo cover lower your idle to 900 rpms and see if the servo turns.
are you getting any lights blinking on the dash???
i belive "reflections" is ment like bound and rebound of the valves... as stated above check to see if the servo is moving... i would guess that the servo isn't moving because you say it dead... when you say its dead do you mean its not moving?? if so check for voltage to the servo in the wires if when at ideal (900prms)and reving a bit you should see voltage in the wires... if not then its the servo motor.. what made you think that the pw valve servo is out ?? does it run good when you ride it???
I cant understand a word of that, where did pills come from? and scooter? relevant?
welcome to the site non the less man.
what I mean by, when I say that the servo motor is dead. I mean that it is not even on the move server engine. but I may well take and measure voltage.
but I now know what is the error servo motor can make power for I have not taken close to error codes. so whose usually be cable crimes often? or is it reaching relays that have elapsed. Where can you get a flawless cable strain that works 100%?
In Sweden, we not only say snowmobile, we say "sled" "scooter" "skobojter"
boy...
1- idle sled to 900 rpms,,did the servo move??
2-are you getting any lights flashing on the dash when sled is running??
i was a bit lost to... i can try this all day though... lol good luck buddy i would say get a new servo motor and try that if not then let me know
i wish i could help ya man, really! i wish i could, but i cannot comprehend what u are saying, i'm just a stupid american, according to most mexicans at least.
man i did that and more for new years.... look at when i posted that, the time... yea i was loaded.havent slept yet, been drinkin for 24 hours.yea it was a good time, Maybe i'll get some pics up :rofl:
My interpretation: The powervalves of my 200 srx 700 do not work. I have to fix the wires (probably the electricity wires he is talking about ). The PV servo engine is dead, but it has worked before. I have heard that the electric wire routing (how the wires are put back in place) is to blame and I am not sure the PV motor is getting any electricity. My dad tinkers with my sled and got the fuel gauge to work again but it seems like the PV servo motor stopped working.
The next thing I think he means is that his father means that wiring harness chaffing or faulty relays is to blame.
Rings and reflections? Not so sure!!!
gotta hate the language barrier.
drop idle to 900 rpms and the servo should open.
this will tell you if the servo is working.
good luck!
