Bender triple Pipes Viper Set up
RXMax
Central MN
Picked up a set of pipes for but did not get instructions. Does any have the setup sheets for carbs and clutches? Would be running it at 1500 ft and then from 6000-9000 ft. Any help would be great!
Thanks!
You have to be joking yammmyhamer the benders work great if you do it right. You have to pull the carb vent lines off. Or you will never find big enough jets to feed it. 7000 k and four years. PIPE IT ALL THE WAY. RXMax
I know but I need the instructions.... Or some instruction on how to set it up.... Laid out for me..
goggle off road.com/bender pipes. there was a very detailed how to on that site. I had the same problem
