holeshot202
Overheating Help
12/21/08
Got a 99 vmax 700 thats overheating consistently.....i'm not sure if theres just that much air in the system that needs to be bled, the water pump is burnin out, or somethiing else....i can only drive a few miles at a time at low rpm's before the engine temp light comes on. the system is pumping coolant because the heat exchangers are burning hot, but we tried to bleed the sysytem through the bolt on the top of the head, but nothing came out and tried adding coolant. It seems like the coolant line near the radiator cap seems to not be holding its vacuum...it doesnt seem to be pulling coolant from the tank but like i said, the coolant has to be flowing bc the heat exchangers are hot, but the engine is hot as well so i'm totally stumped....please help
1/2/09
tried everything you guys said...have bled the system repeatedly with no luck....put a pressure test on the coolant system to check for leaks with no luck either. is there something else that could be causing this problem? the last time we bled the system the right side (opposite clutch) heat exchanger was the only one hot...the rear and left side were relatively cold....with no leak in the system we thought it might be burning coolant having like a cracked gasket or head....seems to not be burning coolant... have no idea what the next step would be ....?
12/21/08
1/2/09
