for disassembly, loosen the bolts in the purple circles first, in reverse order, of the numbers shown....meaning, loosen bolt #6, then #5, and so on. for the 2nd step of disassembly, loosen the bolts in the top pic, which have #'s cast into the crankcase to follow.....loosen those in reverse order too....meaning start w/#16 and then #15 and so on.
for assembly, start w/#1 (cast into crankcase), then #2, and so on....in the top pic. the last step of assembly, tighten the ones 1-6 of the bottom pic, starting w/1 and then 2 and so on.
remember to stage your torques...meaning, don't go to the finish torque of 19ft-lbs off the bat....start at 10ft-lbs on each bolt, then go to 15ft-lbs and then to 19ft-lbs....you understand?
i forgot to add that the 6 bolts in the purple circles of the bottom pics, only go to 11 ft-lbs, not 19 ft-lbs like the 16 bolts in the above pic.
