marty f
i am taking out the tunnel protecters(aluminum)on a 1998 srx700 i have taken the seat out and drill out the rivets that hold the back of the protectors under the seat now i need to get to the ones under the gas tank do i need to remove it and what bolts are holding it in
I was always able to hit the rivets with the air chisel and make them disappear. Otherwise your going to have to pull the tank.
i used a metal chisel and a 5 pound mallet when my track was out to remove the protectors. It worked very well
Why are you removing them??
I believe the oil tank is mounted to the front of the tank, so its kind of a pain in the arse to remove the gas tank.Have to remove the air box etc.
Danger Dog
Remove the gas tank. Just unbolt the oil tank unhook fuel line and vent two bolts on tank and don't forget taillight plug on right side of tank and done. It takes 15 minutes.
BLUE DEVIL 700
would i have to remove the tunnel protectors to run a 1.25 Track?
Depending on the track and which tunnel protectors you have. I have 1" extruded aluminum and my new 1 1/4 Predetor rubs the protectors. I just notched the track in line with the protectors to give it a little room.I did the samething to my Ripsaw.BLUE DEVIL 700 said:would i have to remove the tunnel protectors to run a 1.25 Track?
Some guys just let it wear into the track, and say its good after about 100 miles or so.
Are you planning on putting in studs at any point?
BLUE DEVIL 700
no studs with the 1.25 but i will be using a speedtrack with picks.It's a 1.25 bombadier Track..My protectors look like teflon mabey a half and inch.Sno-Xr said:Depending on the track and which tunnel protectors you have. I have 1" extruded aluminum and my new 1 1/4 Predetor rubs the protectors. I just notched the track in line with the protectors to give it a little room. Some guys just let it wear into the track, and say its good after about 100 miles or so.
Are planning on putting in studs at any point?
BD700, I would leave the protectors in. I would also do some measuring when you install the speed track. Determine how far the studs stick past the area of the track that will contact the protectors(in between the track windows), and be sure it is less then your tunnel and heat exchange protectors.
BLUE DEVIL 700
Yes i think i will,probley see if the track will just wear down on its own.Thanks Sno-XrSno-Xr said:BD700, I would leave the protectors in. I would also do some measuring when you install the speed track. Determine how far the studs stick past the area of the track that will contact the protectors(in between the track windows), and be sure it is less then your tunnel and heat exchange protectors.
weird but i think 98 doesnt have them......they are not there on 98
My 98 SRX didnt have them either. I think 99 or 00 they started putting them on at the factory.modsrx said:weird but i think 98 doesnt have them......they are not there on 98
My 04 Viper S didnt have them either, but thats because it came with the 1 1/4 ripsaw.
SHAMARKEN
98's didn't come with factory protectors installed....
RIVERRUNNER
My 99 did and I took them off
I wish i would have notched my ripsaw instead!!
