Need help with 2000 Vmax 700.
Sparrow
Canada
Hello,
I'm having problems with a 2000 Vmax 700. Idles fine and runs strong wide open, but breakdowns when running 1/4 to 3/4 throttle. It also eats fuel now.
Plug is black and wet other two mint.
The compression is even, carbs cleaned, new plugs, fuel.
Tried moving coil and the it problem doesn't move with it so I'm assuming the coils are ok.
Sled is stock. 19000 trouble free km before this.
Any ideas?
Had that the same problem on my 97. Idled good and wot was strong but anywhere inbetween it just stumbled bad. Turned out to be the plug caps where shot and the stator was on it way out. Trying putting an ohmeter on the plug caps they should read 5k.
