Temp light flashes 4 times
Sanka
Illinois
My temp light is flashing 4 times at full throttle. Fault sheet says tps. Any clue how to set this?
thumb warmer
Do you have the right fault sheet? Mine says it´s shorting in the thumb warmer. Maybe the cable is damaged that´s why you only see it in full throttle.
No, I ment the electric cable to the thumb warmer. Maybe it´s damaged and when you push full throttle the cable bends and the two wires inside come in contact with eachother.
