the sled is clunking at take off
craigjschr
rochester
i own a 2002 viper ER with 5600 miles on it vary well cared for just got my tune up done and today i noticed that when i go to accelerate from a dead stop the sled seems to go clunk clunk clunk till i get going faster. the cluch seems to be good it kicks right in at 4000 RPM then it clunks till i get some speed i dont no if it is normal or not any help would be nice.
thanks
craig
I would say the belt too. Could be a loose heat exchanger protecter being hit by the track.
im going to change out the belt to see if that works. how do i adjust the track. ill check the heat exchanger quards and check the drive chain. hopefully its the belt is that all i should check how do i check the motor mounts.
thanks foor the help
craig
most likely a belt.
to adjust the track pick the back of the sled off the ground and losen the rear wheel bolt the there is a bolt on each side of the skid in the rear. you can adjust the through the track windows. i dont remember the track sag someone else should chime with it.
Could be a worn brake disc also. The key on the shaft wears and the disc becomes sloppy and the it moves aound on the shaft.
sandmanmike1 said:
1 inch at 22 pounds of force. I run mine a little looser though. I use my fish scale to check it.
^^what mike said,,or loosen it up till it ratchets(slips) then back tight till it
just stops..
