ekimsx600
Clutch spring help Turk, VMJ?
I think it's time to change the clutch springs on my 99 sx600. I just put a set of pi center dumps on it and I'm wondering if I should replace the spring with stock or if I should use something different. If any of you clutching guru's have an idea let me know.
If rpm,s & engagement is fine stick with what works. Those centre dumps gotta run at 7900-8100 rpm.
ekimsx600
Hey Turk, you ever set up a sled with these pipes? What would you run for clutching on a 600?
