Clutch springs
ekimsx600
guelph ont canada
Website
www.freewebs.com
Clutch spring help Turk, VMJ?
I think it's time to change the clutch springs on my 99 sx600. I just put a set of pi center dumps on it and I'm wondering if I should replace the spring with stock or if I should use something different. If any of you clutching guru's have an idea let me know.
If rpm,s & engagement is fine stick with what works. Those centre dumps gotta run at 7900-8100 rpm.
I tried centre dumps on my 01 mm. Run same clutching but just add more weight to get rpm,s down. 89L,s work well.
