As the title says are the stock gears in a 00' SRX hyvo or not. I'm looking for a stock 38 tooth gear for a 00' SRX and found a couple on ebay. Only problem is one is listed as a HYVO and the other one is not and is titled as being for an SXR or SRX. I'm not sure which one to bid on.
yes they are hyvo on 00 and up srx
Well, I see that they are HYVO. Now were the SXR's Hyvo. Below are the links to the 2 items. Maybe either one will work.
http://cgi.ebay.ca/Yamaha-snowmobil...14&_trkparms=72:1215|66:2|65:12|39:1|240:1318
hey jay ask harness racer here he will pop u on it he is the guy on ebay that sell that gear ......
richierich
Srx's are hyvo from 00 up and 02 up vipers also.
Sx,sx-r are non-hyvo
Great thanks for the replies.
YAMMIEGOD3:16
ANOTHER TIP. GO ORDER THAT GEAR AT YOUR LOCAL POLARIS DEALER. TELL THEM YOU HAVE A 2000 XCR 800. WAIT TO YOU SEE PRICE DEFFERENCE. 3:16 (yammie tony)
mopar1rules
YAMMIEGOD3:16 said:ANOTHER TIP. GO ORDER THAT GEAR AT YOUR LOCAL POLARIS DEALER. TELL THEM YOU HAVE A 2000 XCR 800. WAIT TO YOU SEE PRICE DEFFERENCE. 3:16 (yammie tony)
tony, i take it, its the same gear?
Any chance someone could look at the ebay items to confirm which item looks like the stock 00 SRX gear. The one listed for SXR or SRX says its from a 00 SRX. Since both sleds don't come with HYVO which is it? Also the other one looks to be HYVO but is it stock? Sometimes you have to shim aftermarket gears and I'd prefer not to. Thanks again!
YAMMIEGOD3:16
RULES YES. AND CHEAPER. 13 WIDE HYVO. BUT ITS 2000 XCR 800 AND UP. GEARS WILL WORK ON 2000 AND UP SRX. THING HERE IS PRICE DEFFERENCE VS YAMAHA. 3:16 (yammie tony)
YAMMIEGOD3:16
LINK TWO IS STOCK GEAR. 3:16 (yammie tony)
YAMMIEGOD3:16 said:LINK TWO IS STOCK GEAR. 3:16 (yammie tony)
Thanks a lot!
BLUE DEVIL 700
Tony if you use a polaris gear do I have to shim it?
both top and bottom polaris cogs will work?
anyone have a 23 hyvo cog they want to sell?
stock gearing on a 2000 srx700 is 23/38 correct? how much harder will I pull if I go to a 22 top gear?
YAMMIEGOD3:16
DEVIL NO. THEY ARE EXACT. PUT IT ON JUST LIKE YAMAHA GEAR. AND AGAIN ITS 2000 AND UP XCR 800.
SRX700guy. DROP ONE TOOTH, ITS LESS MPH BUT BETTER ACCELRATION. 3:16 (yammie tony)
ok so it will hurt my top end only in long speed runs correct? in say a 500 foot or 1000 foot track I will have a higher top speed than stock correct?
BLUE DEVIL 700
im not sure about speed but you will get there quicker for sure..if the sled doesn't spin.SRX700guy said:ok so it will hurt my top end only in long speed runs correct? in say a 500 foot or 1000 foot track I will have a higher top speed than stock correct?
BLUE DEVIL 700
perfect,thanks Tony!YAMMIEGOD3:16 said:DEVIL NO. THEY ARE EXACT. PUT IT ON JUST LIKE YAMAHA GEAR. AND AGAIN ITS 2000 AND UP XCR 800.
YAMMIEGOD3:16
BETTER E.T. SLIGHTLY LESS SPEED. 3:16 (yammie tony)
