00' SRX Gears-- HYVO or not
jaydaniels
Amherst NS
As the title says are the stock gears in a 00' SRX hyvo or not. I'm looking for a stock 38 tooth gear for a 00' SRX and found a couple on ebay. Only problem is one is listed as a HYVO and the other one is not and is titled as being for an SXR or SRX. I'm not sure which one to bid on.
hey jay ask harness racer here he will pop u on it he is the guy on ebay that sell that gear ......
ANOTHER TIP. GO ORDER THAT GEAR AT YOUR LOCAL POLARIS DEALER. TELL THEM YOU HAVE A 2000 XCR 800. WAIT TO YOU SEE PRICE DEFFERENCE. 3:16 (yammie tony)
Any chance someone could look at the ebay items to confirm which item looks like the stock 00 SRX gear. The one listed for SXR or SRX says its from a 00 SRX. Since both sleds don't come with HYVO which is it? Also the other one looks to be HYVO but is it stock? Sometimes you have to shim aftermarket gears and I'd prefer not to. Thanks again!
RULES YES. AND CHEAPER. 13 WIDE HYVO. BUT ITS 2000 XCR 800 AND UP. GEARS WILL WORK ON 2000 AND UP SRX. THING HERE IS PRICE DEFFERENCE VS YAMAHA. 3:16 (yammie tony)
stock gearing on a 2000 srx700 is 23/38 correct? how much harder will I pull if I go to a 22 top gear?
DEVIL NO. THEY ARE EXACT. PUT IT ON JUST LIKE YAMAHA GEAR. AND AGAIN ITS 2000 AND UP XCR 800.
SRX700guy. DROP ONE TOOTH, ITS LESS MPH BUT BETTER ACCELRATION. 3:16 (yammie tony)
ok so it will hurt my top end only in long speed runs correct? in say a 500 foot or 1000 foot track I will have a higher top speed than stock correct?
im not sure about speed but you will get there quicker for sure..if the sled doesn't spin.
