2000 SXR 700 mod help
1324yamaha
lively, ON
I have a 2000 SXR 700 triple and am wondering if there are any cheap and relativly simple modifications that I could do to it if there are could you give me instructions on how to do them
I have a budget of 200$
Check the tech pages. - Thin head gasket (premium fuel required), notch reed stoppers or buy/make a set of spacers, Bore can, proper clutching and jetting. Should be able to do it all for less than $200.
welcome to the site...I have the same sled and there are a few things that can make it much better......reed mod, head gasket peel, clutching will all get you noticable gains.
I live in the Valley if you need some help
$200 is just about right on target for Turks recommended mods. 51/43 Helix is $85, 4.5 & 3.1 gram rivets are $5, 40 tooth gear for the chain case is $40 and if you replace your stock clutch and secondary springs with new ones it's $30. Replacing the stock 22 tooth gear and the chain in the chain case is another $40. Head gasket mod and jetting to 142.5 are other options but I think most are happy with just the above.
