54/44 vs. 54/43 Helix VIPER
ajviper
Michigan
54/44 vs. 53/43 Helix VIPER
Looking to do the common viper clutch mod -- 53/43 Helix and Green Secondary spring. I found a 54/44 dalton helix and wanted to know how different this setup would be... Would I be better off with the 53/43 or will I not even notice a difference between the two being that they are so similar?
54/44 is so close it,s allmost negligible. It may drop you 1-200 rpm,s but pull harder.
Thanks, Turk. I can get a great deal on a 54/44, but didn't want to go with it unless I knew it wasn't going to dramatically change it. It sounds like i would be fine with it and that it will be much better than the stock setup.
