Did you add any material mussel? Or is that just from unrolling them?
			you end up with alot of extra through most of the board.
			Great thanks! Ordered my cat parts last night and going to use a dimple die kit to make some traction holes. I will post pics when I am done
			Thats pretty slick there, nice stuff!
Yamasquaw
 - Jan 8, 2005
I picked up the apex running board edges from haydays ....... In the package from yamaha.......$10 for 2!!! lol. I should have bought the all the ones buddy had.He had lots too! Probably someone from this site more than likely cause he knew of this mod and i told him it was exactly what i was doing.
			devinzz1
why cant i vote!?!?!?!
			devinzz1 said:why cant i vote!?!?!?!
Me either, poll must be closed I'm guessing.
Really cool idea widening those boards!
bump for a looker
			So I guess I have a few questions... Isn't the "roll" on the running board there for support? After asking this, do you need to support the tunnel in any fashion? Also where do you get the filler piece? Close up pictures of the footwell area?
Thanks Mike
			Thanks Mike
The edge you will rivet on is far stronger than the edge that is rolled.  You can get used edges from junked sleds.  Best way is to just order the cat ones listed earlier.
		super1c
Super Moderator
Scott messed up on this, need some help.  Sent ya a pm!!
			Ok I want to try this too, but that scares me. Can you post how he messed up and the remedy. Pictures would be great too. Thanks
		super1c
Super Moderator
Well here's what i did.  When cutting off the rolled up part left in the footwell i cut into the bracket under it.  I was in a hurry and not thinking, first mistake.  Me cutting bracket second.  Not happy but fixable just looking for how to go about it.  The weld for the trailing arm is untouched and solid.  Its only that front half of the bracket and the big plate (brace) on the side by belly pan rivits to it.  First question is it fine left the way  it is?  This looks to be non structural but i dont know.  Second should i just drill it out and have it welded and rivit back in?  If i do take out the bracket what kind of rivits art those big head ones on the foot rest that go all the way to the trailing arm bracket.  I have tons of the yamaha double grip rivits so the small ones im good, just need help finding big ones.  They look pretty heavy duty.  Cant find them on the yamaha  fisch so need help there.  Need some advise on this one guys, thanks.
		super1c
Super Moderator
Wont let me edit or post pic.  I think cause it was a poll and its closed.  Can any of the mods fix this so guys like me that mess up can still post for help?  Here is a link to pic.  http://www.totallyamaha.net/forums/showthread.php?p=586788&posted=1#post586788
		staggs65
test
		staggs65
pics are working for me in this thread super. how were you trying to post the pic? I did it with an IMG code through photobucket (how I always post pics) I've got some ideas on your repair too but I want to go look at one of my stripped down chassis' tommorrow first. I'll pm you tommorrow
		super1c
Super Moderator
Still cant post pics or edit.   Not sure whats up cause its just this thread.  I always post pics through "go advanced" or post reply.  So not sure what up, maybe just me.
			took a look at the M7 running boards, they are not bent like BTV's are. BETHEVIPER, did yo bend your to fit??
			Use ZL running board edges. I used M7 but honestly I regret it... I got it to work but it could be better.
			SXRider7Hundo said:Use ZL running board edges. I used M7 but honestly I regret it... I got it to work but it could be better.
Any specific year or model?
