journeyman
Does any outfit sell such a thing? I thought I saw someone had these awhile back. I keep forgetting to check it out. Every time I ride in the UP or Northern Wisconsin (sugar or lake effect snow) I end up getting that snow dust around my carbs and it starts to babble on low end. I can quickly remedy it by turning on the carb heat bypass valve......but I actually get worse gas mileage if I run the coolant through the carbs all the time. Naturally the snow dust comes from the guy riding in front of you, but I rarely lead when I trail ride up there.
thanks
thanks
Check out outerwearsracing.com, sorry haven't quite got whole cut/paste send link thing down yet!
..SNAKEBIT..
I think Mountain Performance has them?
found a Yamaha part number SMA-8EKAI-RK-IT
dont know if its still good but it might help you
Snake
Snake
WNYViper
So far all I am finding is 'Obsolete Part' for that part number... found an old thread about em though...
http://www.totallyamaha.net/forums/showthread.php?t=9631
02ViperMtn
i am interested as well if anyone finds them. It appears that they are dicontinued, but someone may find a source that still exists.
craigjschr
i am looking at the ones from outerwearsracing for my 02 viper and my 01 sxr i was wondering if these are good ones to get will it keep the snow from out of the motor or do i need the vent ones to becuse i cant find them.
mod-it
I think Hartman has them...if your talking about the pre-filters for them.
journeyman
Thanks, I also noticed that the Yamaha part number is no longer available. I did check out outerwears. Does anyone know exactly what you get? Is it a cover for the airbox or the actual cold air intake ducts on the hood? Here is the link:
http://www.outerwearsracing.com/proddetail.asp?prod=7349
go to www.hiperf.com they sell the material in sheets and you can make the covers for the intake scoops on a viper. I ran both on mine the air box cover and the FAI covers, made a big difference. Maxdlx
Pre-filters on the airbox are a must if you ride deep powder.
..SNAKEBIT..
I also run both ram inlet filters and air box filter on my 2002 Viper
I think I got them from Mountain Performance of maybe Rich??
journeyman
Thanks everyone!!
journeyman
maxdlx said:go to www.hiperf.com they sell the material in sheets and you can make the covers for the intake scoops on a viper. I ran both on mine the air box cover and the FAI covers, made a big difference. Maxdlx
Thanks on this tip. What did you use to fasten the material for the scoops?
Yamasquaw
- Jan 8, 2005
If you don't wanna spend big bucks on the sheets of pre-filter material , i found a thread on 4-stroke forums about a material called ORGANZA, Its a very tight fabric that breaths well but i may try some scotch gaurd on mine to see if i can make a bit more water proof. 4'x4' sheet for 6 bucks. Any fabric store will have it and comes in lots of colours. I figured it was worth a try.
journeyman
Yamasquaw said:If you don't wanna spend big bucks on the sheets of pre-filter material , i found a thread on 4-stroke forums about a material called ORGANZA, Its a very tight fabric that breaths well but i may try some scotch gaurd on mine to see if i can make a bit more water proof. 4'x4' sheet for 6 bucks. Any fabric store will have it and comes in lots of colours. I figured it was worth a try.
I might check that out. I was thinking of making a velcro edge on it and fastening it underneath the hood around the FAI scoops and making it a quick release type of thing.
