heated grip problem/question
comquat1
earth
I recently bought a 91 phazer II and don't think the heated grips are working. Also, I had some issues with the lights burning out and through searching found that i should be looking at getting a new voltage regulator assy which i have ordered. My question is will putting in a new one possibly make my grips work again? Not sure if that part is tied to the grips or not as well. Thanks in advance, it's nice to find a forum with some phazer knowledge finally.
might fix the warmers ...but i would think they would still work ..but just be really hott due to too much voltage ...or they might have got burned out from too much voltage ....
The grips are not tied to the regulator. Standard circuit test procedures will need to be done to locate the problem. There is a wiring diagram in the operators manual.
Is there an online manual somewhere for these things?
Installed the new regulator and took it for a spin, looks like everything is a-ok as of now. While installing a new headlight i found the cause of my non-working handgrips.... the wiring is all stripped up.... :mad: :mad: How it got like that is beyond me... I'm going to pick up some wire and see if i can replace the messed up pieces. We'll see again how much this sled wants to come back, but all i know is i froze my hands off going out tonight with temps in the teens or lower.
