mm700ak
This last summer I waterskipped my snowmachine and it was running good with lights and all of the electrical guages working. After storing it for the summer and starting it this winter, I don't have any lights, brake lights, rpms...pretty much no electricity to anything else but the spark plugs. I tried changing the cdi box and the other two cylinder shaped things by the secondary, and it still won't work. Would it be anything to do with the magneto? Because it seems like it's running good. Please HELP. Thanks
Chris
Chris
wmcquay
I think it could be wireing problem check harness under engine for rub thr ough look for bad connections,melted plugs etc.When my stator went motor had no spark.Wire diagram and ohm meter make job easier. Good luck.
could be a voltage regulater in front of your left knee ....i unpluged mine and forgot to plug it back in and had no electric ...might look to see if yours is unplugged or short in the wires to it ..or burned out ...most likely it is wire harness under motor try wiggleing and see if you get anything
mm700ak
I know it's not the voltage regulator because I changed them out. I also changed the two cylinder shaped things next to it, and it was still the same. For the wiring, I took all of the tape off of the whole wiring to the lights, and didn't find anything. Would it be something as simple as a loose wire to take out all of my electrical? Did I mention that it starts?
TJ500
check the "Load Control Relay" (black), near left footwell just above large pin/clip for belt guard... try jumping across contacts... you'll need a schematic for your sled to find correct terminals.. tj
http://www.yamaha-motor.com/sport/service/viewmanuals/viewmanuals.aspx?ls=sport
mm700ak
Thanks Alot Tj!!!! I Changed That And Everything Works. Thanks Again
