going thru srx, just bought
staggs65
Sabattus, Maine, United States
new to the sight, great info! just picked up a 00 srx 700, first thing i did was check the power valves, all three pull-thrus, three new ones. after seeing that I decided i'd rering for piece of mind. mag piston has alot of knicks on the top as well as scuffs on the skirts, going to replace, the others all look good (haven't mic'd em though), should i just replace the one, or all three? also the head on the mag side had knicks in it, should i find a used head or run er. i'll have more questions i'm sure as i go thru the rest of the sled, but i want to cross this bridge first.
How many miles on the sled? Depending on miles, if the other pistons mic out within spec and look good, then if it was me I would probably run them.
