kl-ze
Hello,
a couple days ego my sxr700 seized on me just like that going real slow; id say about 15-20 mph.
didnt see any warning lights on the dash, i think. and never had the light blink at start up 3x, as I have found out it should by reading on this forum, so i didnt even know if it did came on!
anyways, here is the break down;
recoil was jamed, seized so i opend the hood, and was able to turn the crankshaft using my hand back and forth. atleast the crank wasnt seized and that was good enough for me to call it a night!
today i got the sled inside so i can work on it abit;
took of spark plugs and all 3 were dark black and center electrode was white at the tip.
took of bender triple pipes and was able to see piston damage on mag & ctr cylinders, but more on the mag side cause it gets more heat i assume and the rings looked shot. so basically its a scar on the exhaust side like you normaly see from shot rings.
will take everything apart tomorrow and see what exactly is damaged.
maybe i can get away with piston/rings and hone job on cylinders.
but main concern i have is why this happened, as this is not my first 2stroke rebuild! i dont want to do any extra this year
and would like to hear some main points to go thru and atleast test or inspect so that i get this right the first time!
oh one more detail, a friend of mine put almost full tank of 87 octane gas that day before riding!, this was second run this season, and sled was working great everytime before...
thank you all!
Bender triple pipes
Full Bender Clutches
the rest is just usual cosmetic stuff
thank you all!
Bender triple pipes
