My buddy has a strong running Formula III 600 and every time we race he waxes me. his is stock and mine is piped and clutched but in 1000 ft he will kill me. we are close out of the hole until about 70-80mph then it is over. help me please
Mighty
I remember when those 1st came out, quite a handful.......Good Luck.SRXicer said:My buddy has a strong running Formula III 600 and every time we race he waxes me. his is stock and mine is piped and clutched but in 1000 ft he will kill me. we are close out of the hole until about 70-80mph then it is over. help me please
tedgoesfast
what is your hp with pipes and what is it turning for rpm
i was told from the guy i bought them from they should make about 120 hp and run 9000 he got them second hand as well and didn't know what make the were he thought they were aaen
tedgoesfast
if you knew what pipes thy were you could get a setup from turk he would know thats for sure
VenomMod
If they're AAEN, they don't make as much power as other brands of pipes for that motor (I've got some AAEN's on my Venom). I've noticed that I start to get the extra power at mid to top end. Check to see what you're running for RPM's. If found that the second I go over 9100 RPMs, the sled falls flat on it's face. I've got mine to run 9000-9050 on decent runs, and it'll grow some long legs.
never been able to make aeen yamaha triple pipes work well.
Triple X
Mighty said:I remember when those 1st came out, quite a handful.......Good Luck.
The 95's made around 125hp, they gave alot of bigger sleds fits.
The Formula III 600 i've been told just run good and that there is no way my sled (or wife's sled) will beat one I know my SRX will but i just never heard of a yami 600 out running a skidoo 600
RIVERRUNNER
I have never lined up with one........but I would like to see what happens!! I should be around the same power as you are so I don't know if I will stand a chance???
you would have a few HP on him so i'd say NP....RIVERRUNNER said:I have never lined up with one........but I would like to see what happens!! I should be around the same power as you are so I don't know if I will stand a chance???
nothinbutansrx
The early formulaIII 600s were well underated to qualify for the ovals back then, actually 130 hp. With pipes on your sxr your prob only going to get around 120. Your better off beating him in the bumps, f chassis skidoos are tanks.
My SRX 600 will eat a formula III in 1000 FTSRXicer said:The Formula III 600 i've been told just run good and that there is no way my sled (or wife's sled) will beat one I know my SRX will but i just never heard of a yami 600 out running a skidoo 600
RIVERRUNNER
Well thats good to know....now I really want to line up with one!!
