hows this for oil usage?
Thumper1
Western Illinois
in the northwoods of WI last week and it was cold! rode 377 miles and used 1.25 quart. at that rate, i could go about 1000 miles without adding oil.
stock '04 viper, stock oil cable setting.
sounds lean ....one quart per tank i belive is what is the rule of thumb....better do some research lots of vipers losing crank bearings lately ...02 i belive but have herd of all years doing it ....
Thumper1 said:
went up with full tank, filled up twice and have about 1/2 tank left.....so roughly 30 gallons.
wow lean thats like 96:1 if my math is on..surprised it's still running.
1.25qts=40oz's to 30 gals of gas=96:1
rule of thumb is around 1qt to 1 1/4qt to a tank(12gals)of gas
if those numbers are accurate, may not run for too much longer... richen oil mixture asap... and carefully keep track of fuel used, as well as oil used... miles traveled means little since driving conditions constantly change.... tj
Do the cables stretch? Is this only on the Vipers? On my 700 SX use less oil than wifes 600 DLX SX. Cable is adjusted same.
No, cables don't stretch at least not on mine(always checking spec)vipers
were just lean from the factory.
i would set em to 19-20mm and go from there,check consumption if not
happy and seems to rich cut back some.
i have 5500 miles on my viper so far with this oil setting. maybe why i haven't had to clean my power valves??!!! buds '02 viper is also the same with about the same mileage. we used the same amount of oil.
i will check tonight on both sleds the oil cable setting. looking at all the posts on bearing failures, might just have to richen her up. yamalube is cheap.
damn guys i wish i was getting that kind of oil consumption.. i have a 02 viper with mbrp can and i rode 120 miles the other day and went through about 2 1/2 quarts possilbly alittle more should i try leaning it out alittle bit?
yes you could,check your cable cable at the joint see if it's unseated if not
check your gap spec. your too rich.
how much gas did you burn in that 120??
