RIVERRUNNER
I am trying to get my rpm down on the shift and top end a little and would like to know what a gram in each weight will bring my rpms down to, on average. I have searched and can't find it!!!!! The other post was confusing about one gram total or one gram in each. I am going to have to use washers under the rivits because I am loaded!
Triple X
A one gram washer added to each weight should bring down rpm's by 100-200. How much (rpm) are you over reving?
RIVERRUNNER
I am at about 8400 - 8600 when I initally pin it and it walks up a little from there all depending on conditions of course. I have been told that it likes 8300-8400 rpm for my 600. I have the secondary set at 70......and I know I can go to 60 but I ride in the powder and tight trails and I would like to keep my secondary up in the 70-80 ranges. I am a 160 pound rider with 8df weights loaded g-w-g primary and a bender 53-45 helix with a green spring. I have ordered the weights from yami and all I need to do is get some washers and peen the rivits over them correct. Going to have 5.5 in the tip!! Oh and test ofcourse!!!!!
you need to be 82-8400
add 1 washer under each rivet
your losing a lot of hp at present rpm,s.
RIVERRUNNER
Thanks again turk!!!!!!!!
otis700
rivets
Instead of using washers, you can also use the 5.5 gram nut/washer combo. I believe I got these from hauck power sports years ago. I have used them in my 700sx for many years, just used some threadlocker.
Mark
Mark
RIVERRUNNER
I was a the site and I was looking for these...I did a search and someone else was talking about them, but when I to the site I couldn't find them. Any ideas????
Give them a call @ 715-234-6195 - good to work with.. order them over the phone. have used them, come in handy once you get that d..b rivet out.. (limited tools at time).
PNPerformance
RIVERRUNNER Have you tryed heelclicker clutch weight's you can add all diffrent weight's too the heel or too the tip too find your combo that your looking for.
RIVERRUNNER
I haven't yet but I have thought about it.....I have talk to some and there is quite a bit of testing involved, from what I hear and some people have gotten away from them....a least that is some of the stuff I have read. But there are also a ton of people on here that swear buy them....so thats why I don't have them yet...don't know if I need them!!!!!!! How much is there to gain...1-2 sled links in 1000'????????
