sickric
I have been having a pressure build up in my coolant bottle. After the machine is warmed up , I stop somewhere along the trail and shut it off, a little while later it will bleed coolant out the overflow. ( No Visual leaks anywhere else on the motor.)
I did a compression test today , = 120 mag side 120 center 110 pto side.
Do you think the low pto side and the pressure problem are related ?
Is the 10 PSI difference something I should be concerned with ? (rule of thumb is 4% difference right?)
All plugs are beautiful tan color, Sled runs and starts great, has 3400 miles on it.
Any thoughts ?
Any thoughts ?
I'm not a viper guy, but didn't they run staggered compression on the PTO side so that the carbs are jetted the same on all three?
sickric
I am not sure about that, good question, anyone else know about this ?
9801srx
thats right. there usually about 10 lower on the pto.Ryan B said:I'm not a viper guy, but didn't they run staggered compression on the PTO side so that the carbs are jetted the same on all three?
bluebandit98
i had a head gasket go on my 98 xtc 700 an it would build pressure in my coolant system an blow the cap off of the colloant overflow botle.
Yamasquaw
- Jan 8, 2005
Just did one on my Viper, has just over 12,000km's/7500miles approx. And it was 135,135,110. Which i thought was great considering havent touched it yet.
sickric
O.K. Thanks for the replies everyone. Maybe the compression is O.K. I will try and fiind out why I am building pressure in the coolant bottle.
02ViperMtn
i read in a recent thread that i recall the issue was a head gasket leak. A tell tale sign was bubbling in the collant overflow while the machine was running.
could be the head gasket? does it run hot and overheat? if so it could be a air pocket in the cooling system somewhere that is causing it
