teather switch install
tjsands12
West Bend, WI
i just bought a maier teather switch for drag races and need to install it. its got a black and white wire on the switch. what do each of these go into? just want to do it right the first time before i go cutting wires and stuff
You have to wire the tether in parallel to the kill /stop switch.(on handlebars).
I drilled a hole and installed my tether switch next to the thumb and grip warmer dials.
The white wire on tether goes to black with white stripe wire on kill.
The black wire on tether goes to black on kill (this same wire turns to brown color on one side of the white 3 way plug).
You can use a 3 way connector when making connections. What I am saying is you are just jumping into the existing wires while keeping the original connection.
I hope this helps.
