high country
just wanted to pass this along for the rest of you. I poped my primary and decided to go to a p85 since they are half the price and twice the quality. I found the tapers on the 30mm poo's to be the same as the mm700....30mm 1/10 taper. the clutch is a slip on, the bolt needs attention. the stock mm700 bolt is 1/2-20 but is too small on the shoulder to safely use on the poo. I found a 1/2"-20x7" bolt and trimmed a touch off the end, also a 1/2"-5/8" shouldered bushing to fit the clutch and bolt perfectly. this made it a perfect fit. I am in the middle of weight experimenting, but it looks like 10-58's will work for my elevation, if not I will trim or go 10-56's. spring is almond.
this will be tested this year, but looks like a winner.
