broken rings
swmichsx
niles michigan
200 miles ago i rebuilt my top end. everything was checked and well within spec. yesterday my sled broke a ring and trashed a cylinder. i used brand new pistons , rings and gaskets. they ere the SPI ones. my sled is a 97 SX 700 and the bad cylinder is the mag side. just wondering what might have caused this?
did you check the ring end gap before assembling? some times rings need to be filed to get enuf end gap,with out enuf the ends butt together when they get hot and break.
yes i did. i filed them myself and constantly squared them in the bore to check. the other 2 cylinders are fine.the were installed correctly as well.
The ongoing rule of thumb here is to use OEM parts if you want reliability. I know that doesn't help you in your current pickle, and it doesn't explain what actually happened, but it may help alleviate future pain.
i know. i will be using yamaha rings on all three cylinders when i put it back together. i have heard that the SPI pistons are good but the rings suck!!! i believe!!!!!!!!!!!!!!
i will look right now!!!!!!!!!! nope, the pin looks just like the the ones in the other 2 cylinders. the gouge marks are actually on the intake side.
