no1chevyboy
hi i was wondering if anyone nos what the hp of a 1996 v max 600 xt is and at what rpm it is and how much hp is gained by putting on twin gyt pipes i put on pipes, jetted did primeary clutch and was running around 8700 shift out had max weight rivit at tip thought that was too high so had stock helix for 1998srx (47)and changed spring pos to 3/3 was (41) 2/3 now am running around 8100
super1c
Super Moderator
I dont know the HP but the stock engagement it about 3700 rpm and shift is about 8000rpm. i run stock except for thined headgasket and carbon fiber reeds and stay pretty close to these rpm's. This is from the service manual but i could not find any spec's for stock HP.
no1chevyboy
ya i cant find hp anywere or at what rpm even be fore i put pipes on shift was at max rpm 8300 in instructions and engagement was at 3500/3700 now with p/p/p spring in primery engagement is 3900/4000
You need the higher engagement as the pipes hurt on the low end and yuo will have a big bog. I had a96Xt with twins and it finally came alive around 20 mph. HP Gains with twins I think was inthe 12-15 hp range.
no1chevyboy
thanks for info, what is hp of motor? ok just took for 30mile run at start engagement was 3900/4000 at end of run engagement was 3500 has dead spot from 5000/5900 then scoots pulls right up to 7900/8000 and slowly gets to 8100/8200 got 90.8 on gps hole shot stinks jump ,flat ,pull. if i go slow on throttle and hit 5000/5900 which is almost half throttle will do nothing until it hits half throttle then the rocket takes off can anyone help me with my problem. stock weights,ppp spring in prim,47 helix 3/3 spring % in sec. gyt twin pipes jetted main155, pilot stock,needle at 2.5, pilot screw at 2
Yamaharida
Check the condition of your rollers and weights. Check for flat spots and make sure the bushings are in good conditons. My clutch was acting eratic with dead spots at mid rpm and that was the problem.
bluebandit98
yea the rollers or the inner an outter bushings will do that jus fixed mine on my 700 xtc an now its like a different sled
no1chevyboy
ok been messing with it all bushings are good rollers good, found that bad spot is in needles and were secondary starts to shift put needles were they are stock and it made a difference alot smoother if you have to drive in slow zone 15/20 had ppp spring with 2 shims and couldnt get engagment high enough so changed to hauck blue now engagmant is 4000/4100 which is ok and changed helix to hauck k which took secondary shift(bad spot) two around 5900 but after shift drops to around 5500 when driving slow, but now out of hole is good and can only check wot in about 1300 ft and am pulling 8500 not full shift, have 6.7 grams per weight started with 5.3 stock next will try ether 7.2, 7.6 or 8.1 per weight i think those are only combos two bring down wot rpm but dont know how to fix bad spot 5100/5600 have to keep low speed load out of that range
cougar1985
think i seen a artical on google recently that said hp was around 91 or 94 hp.
braindead1684
Found this from a long time ago on here some scary numbers towards the bottom.
Stock Vmax 600: 96.4 hp @ 7750 & 65.8 ft lbs tq @ 7500
Aaen Single: 99.4 hp @ 7500 & 69.6 ft lbs tq @ 7500
Yamaha GYT Single: 97.9 hp @ 8000 & 66.2 ft lbs tq @ 7500
SLP Twins: 108.8 hp @ 7750 & 73.2 ft lbs tq @ 7750
PSI Twins: 107.1 hp @ 8250 & 68.6 ft lbs tq @ 8000
RPC Twins: 106.7 hp @ 8250 & 67.9 ft lbs tq @ 8250
Bender Twins: 108.3 @ 7750 & 73.4 ft lbs tq @ 7750
It should be noted that Dynotech also measured and compared the Bender & SLP twins and they came out with exact same pipe measurements and the results netted dang near the same HP & TQ readings.
Turbo Vmax 600 7 psi: 131.3 hp @ 7750 & 90.5 ft lbs tq @ 7500
Turbo Vmax 600 9 psi: 141.7 hp @ 7500 & 99.2 ft lbs tq @ 7500
Turbo Vmax 600 11 psi: 151.4 hp @ 7500 & 106.3 ft lbs tq @ 7250
Turbo Vmax 600 12.5 psi: 162.3 hp @ 7900 & 109.3 ft lbs tq @ 7700
no1chevyboy
thanks brain but they didnt do twin gyts wonder why?
braindead1684
I wondered the same thing, i believe it has been noted the the bender twins are very similar and therefore the same or close to the same numbers.
Those numbers make you want to throw a turbo on too don't they
no1chevyboy
ya alittle to much for this sled
braindead1684
Ya but it would be so much fun
I'm not about to do it myself i like to ride it more then a couple times between rebuilds
no1chevyboy
ya lol but does yours steer hard?
braindead1684
Mine steers good a lot better with the plastic skis and new carbides darts like crazy but very controllable.
no1chevyboy
ya i got usi skis with 4 inches of carbide it doesnt push its just a work out slicing through the woods have to go stop to stop to turn
braindead1684
Mine was like that when it was studded the idiot i got it from had almost 300 studs in it. Pulled the outside and dropped it to around 144 and it could turn but still pushed with worn carbides, i have 0 studs and 2" carbides and cab turn REALLY tight now.
You may want to turn up the front shocks. That will increase the ski pressure which will keep them planted and let you turn better. I only turn about half way or so around corners.
no1chevyboy
had 96 thunder cat that would go through with a lot less effort and quicker
no1chevyboy
ya right now there at 9 clicks
