Be sure to double check you mount bolts after she is run a while.
xsivhp
ttt - any updates????
fourty.fourths
That set up is awsome! Im a old SkiDoo guy turned blue.Lol. I torn between doing this set up or a M10. If you could let me in on details on the hole placement for the SkiDoo setup in the tunnel
bluewho
Its pretty easy really move the tunnel washer on one side behind the one on the other side and drill.Do the same on the oppisite than remove very front mounts,,,you will have to grind the rivots and place these back to were needed.23 1/2 or so.Check the mount distance on the doner.
