bluwulff9
Hey guys just wondering.  Putting stock srx pipes on a viper, good idea or bad? another question how are ohlins shocks on the viper.  Do they ride stiffer or are they about the same as stock shocks
WNYViper
Here is an email I received from BETHEVIPER about doing the swap, I thought it would be a great project but then I saw what it was going to take to make it happen, so I went out and bought a SRX, lol, lot easier...
BETHEVIPER and ConceptCarbon both have SRX pipes on their Vipers, they'll probably chime in, just figured I'd share some of the info to get your wheels turning, lol
			do a search on my name and srx piped viper.
you will need
pipes
muffler
chain case cover
srx muffler mounts
01 cdi box bypass wire for temp sender
exhaust manifold extensions
recut head or use cut srx heads and megapower water rail
alot of cutting and fitting of pipes into bellypan and under hood
ends of pipes need some tweeking to get them to fit as well.
bluwulff9
Thanks for the tip.  It is good info thanks.
