Trailing arm skiis on a POGO?
jwiedmayer
Manchester, MI
Is it possible to put the skis from the trailing arm sleds on a POGO front end? How much modication is necessary to get it to work?
I did the modification without the measurement off of the tech section in about 2 1/2 hours. Mostly alot of measuring and fine tuning. You will have to have a longer mounting bolt. The hardest part of the job is getting the original ski bolt out of the sleeve.
