The service manual references a tool to remove the secondary on my 89 ovation. I can't remember needing any special tool to take off the secondary on my 600xt or my srx. Any help?
if it has a jackshaft for the clutch it should come off the same way as your srx. if the clutch is right on the chaincase then you will probably need that tool. i do not know as i never had to take one apart with the clutch on the chaincase.
You're right I just found a diagram, there's a key and the clutch is held by a nut threaded on the the jackshaft instead of a bolt... Doesn't look like you would need a special but he nut might be seized.
the secondary is a tapered shaft , with keyway. u need a steering wheel puller to pop clutch off shaft . u will see 3 notches to slide 3 bolts in to use puller pressing against shaft .
